585,970 active members*
4,299 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Appreciate Help - Duplomatic Turret Fault
    Jul 2009
    Question Appreciate Help - Duplomatic Turret Fault
    Hi, we're running a Colchester Combi K4 with Fanuc S/W and Duplomatic Turret.
    Keep getting Turret Errors on Control panel.
    Have change UNC board and Duplomatic Control card and now the fault is slightly different. The turret indexes as normal but sometimes doesn't lock in position. Instead the turret vibrates (clockwise/anticlockwise) about 10 thou about it's locking point. Sometimes it then locks, but often it just keeps vibrating and the Turret light on the control panel flashes on and off quickly and the contactors on the Duplomatic control card click in and out frantically, the locking sensor also flashes on and off. The only means of overcoming this fault is to power off then manually reset/lock the turret and try again. Also, when manually locking the turret, winding clockwise until the solenoid drops in and then winding anti-clockwise until the resistance is overcome, as soon as the resistance is overcome there is a clicking noise as though something is springing into position? Is this normal? or is it part of the problem? Any help is greatly appreciated.
    Sep 2009
    Marked! I will come back to check this soon!thanks a lot.:-)
    demande credit
    immobilier simulation pret de france taux calcul
    courtier
    Une simulation credit immobilier de France
    a faire un
    pret.
    demande
    credit immobilier simulation pret de france taux calcul
    courtier
  1. New Guy need Duplomatic Turret help
    By raygun in forum Cincinnati CNC
    Last Post: 12-22-2022, 04:11 AM
  2. duplomatic tool turret and other retrofit questions
    By panaceabea in forum Uncategorised MetalWorking Machines
    Last Post: 06-25-2017, 06:06 PM
  3. DUPLOMATIC TURRET
    By TIM_SMALL in forum Uncategorised MetalWorking Machines
    Last Post: 11-07-2009, 11:11 PM
  4. Newbie needs help with Duplomatic Turret
    By raygun in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2008, 09:46 PM
  5. duplomatic tool turret with mach?
    By panaceabea in forum Mach Software (ArtSoft software)
    Last Post: 09-17-2008, 08:05 PM
