585,977 active members*
3,700 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 4- anyone have manuals or experience with them?
    Feb 2007
    12
    Just picked up a Puma 4 lathe. I think it was build in 1991. Unfortunately it came out of a storage facility and didnt have any of the manuals with it. I powered it up and everything seems to work good except for the turret. Its stuck unclamped and when I try to do a toolchange I dont get any response. I'm going to start pulling it apart to see if something is stuck mechanically first. The machine is pretty dirty so I wouldnt be suprised if the turret just needs a good cleaning.
    I was wondering if anyone has a wiring schematic for this machine and/or an exploded view of the turret. That would make diagnosing this alittle easier.
    Also, if anyone has run one of these or worked on one in the past, what problems with the turrets did you have?
    chop
    Not sure the electrics will be relevant to your machine. but they are probably very similar.
    Attached Files Attached Files
    Feb 2007
    12
    Thanks, that should help me quite a bit.
  1. Looking for DAEWOO PUMA 10S-2T Manual
    By zephyr in forum Daewoo/Doosan
    Last Post: 04-11-2016, 01:11 PM
  2. Daewoo Puma 6 with 3tf
    By mmxmb in forum Daewoo/Doosan
    Last Post: 04-06-2011, 01:36 PM
  3. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  4. I Need to buy a Daewoo Puma 8
    By gcrudgington in forum Daewoo/Doosan
    Last Post: 10-20-2008, 11:24 PM
  5. Daewoo Puma 200
    By williamsxu in forum Daewoo/Doosan
    Last Post: 01-17-2007, 11:52 PM
