584,858 active members*
4,594 visitors online*
Results 1 to 14 of 14
    189
    Wink 3d probing, must be a faster/better way!!
    Ok, I'm using the "digitizing wizard in mach 2/3" .
    It's basically a "bed or nails type process whereas the z probe moves up and down for every point based on the step-over for x and y.
    What would really speed things up would be program that would command the probe to move horizontally as well as in z to provide a more expeditious result.
    Anybody have anything better the the simple up/down/move to next point?
    L
    Is a sentance fragment?
    Download the digitizing plugin. http://www.machsupport.com/plugins/Probing.m3p
    Double click the file after you download it to install it.
    189
    Is this probing wizard different from the older version. The older version was still a simple "bed of nails" brute force algorithm.
    L
    Yes, it's different.
    Jan 2008
    24
    Probe information
    I have just procured a new machine probing software package from M&H Probing Systems. The software is very affordable and pretty much bullet proof. With this software in 5 axis mode, the probe utilizes I,J,K vectors for optimum performance. Check them out on the web.
    Chris
    Jun 2006
    3063
    Quote Originally Posted by HAMMER66 View Post
    Chris
    How do you classify affordable: $100, $1,000, or $10,000?
    I checked their web site and they don't mention prices at all that I could see.
    Mike
    189
    I downloaded the new wizard and it just does the same thing as the old version.
    Up/down until it strikes object, all the way back up, repeat.
    Why am I not seeing anything different??
    Larry
    It's not a wizard. You're using the same one as before. It's a plugin, and should be under the plugin menu.
    189
    OK, thanks for the help all.
    I got it working!
    A couple of things I can pass on to others who might have some of the same issues I had.
    I had multiple versions of mach 3 on the computer controlling the cnc mill. (bad idea!) When you install the digitizer plug-in it will only install to one of the versions. (in my case, not the one I needed)
    Will post some scan's in the near future.
    L
    189
    Whoops, spoke too soon.
    Still get Previous SEQ ... and the file where the point cloud is to be written is empty.
    Arrrrgh!!!
    I think I gave you some bad info. I've never used the plugin, so was going by memory.
    Did you use Configure > Config Plugins to enable it, then restart Mach3 and it had it's own menu item (3D Probing)? (Just to make sure it's the right one).
    Then, are you using Probe Object with Grid?
    That's the one I was talking about.
    What version of mach3 are you using?
    I saw a post on the Mach forum asking about pausing or stopping the scan, but there were no replies. So, it doesn't appear that you can stop it.
    Here's the original thead on it from Art when he wrote it. You might find some help in there.
    http://www.machsupport.com/forum/ind...ic,1196.0.html
    189
    Hey Gerry,
    Thanks for the help here.
    I'm using the plugin and have do everything you outlined in your post. I'm using probe with grid. Using the very latest (non beta of Mach3)
    I'm going to try to install it on another computer and see if the software runs any dif on it.
    L
    189
    Tried this on another computer and no luck. Same thing.
    Has anybody had any luck with this addon?
    189
    Thumbs up
    I tried downloading and installing the older version of Mach 3 but the plug-in won't install to it.
    Still no luck.
  1. how to get motors to go faster?
    By stk2008 in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2009, 03:56 AM
  2. Want to go faster
    By doesitfloat in forum Gecko Drives
    Last Post: 11-14-2007, 07:21 PM
  3. Faster TM1?
    By drewmeister in forum Haas Mills
    Last Post: 02-21-2007, 05:27 PM
  4. Why is speed faster than I set
    By monte55 in forum Machines running Mach Software
    Last Post: 11-04-2006, 05:48 PM
  5. Is the new server faster?
    By cncadmin in forum Polls
    Last Post: 03-14-2004, 02:03 AM
