585,763 active members*
4,298 visitors online*
    Feb 2008
    23
    run time estimation
    I have been doing a lot of estimating recently with more on the way. It seems to me when I use a canned cycle for the lathe such as G76 the time only shows one pass instead of many passes and the time estimate comes up short. Does anyone else find this same situation or is there something else I should be doing?
    765
    This is a known issue with the lathe run time estimation. Since NCPlot only shows the final profile for the canned cycles the run time is based on just the one pass. Until we get it to display all the roughing motions, the run time will be short.
    Scott
  1. time estimation
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 04-23-2009, 10:56 AM
  2. Run time estimation
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 08-04-2008, 04:54 PM
  3. Time to Buy
    By Gorillakilla in forum Stepper Motors / Drives
    Last Post: 06-24-2008, 09:52 PM
  4. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  5. X2 Conversion Time (shopping time)
    By Micro Rotors in forum Benchtop Machines
    Last Post: 03-04-2007, 06:11 PM
