585,560 active members*
3,298 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil SX3 spindle play and fix
    Oct 2006
    68
    I notice there's quite radial play of the SX3 spindle. I hold the spindle lower end (the tool holder) with one hand and hold the top end with another. One hand pushes, one hand pulls, then reverse push-pull, I can feel the play. I don't think this is normal. Before I strip it down to find out the problem, did any one fix such problem before? or any recommended way to tight up the spindle?
    Many thanks :cheers:
    David
    Jul 2006
    741
    I do not think it is normal at all.
    Mine has no noticeable play, though I'm sure if I put a DIT on it and gave it a go we would find something.
    Jul 2005
    969
    you sure its not the z gibb that are loose
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  1. Syil X3 Erratic Spindle Speed with Mach
    By reithguitars in forum Syil Products
    Last Post: 01-21-2017, 08:43 AM
  2. Syil Spindle has quit working
    By marco928 in forum Syil Products
    Last Post: 03-16-2010, 07:01 AM
  3. spindle to pully play jhead
    By andrewbishop66 in forum Bridgeport / Hardinge Mills
    Last Post: 06-01-2009, 12:56 PM
  4. Syil X3 Mill Spindle Speed Calibration Procedure
    By Chrisjh in forum Syil Products
    Last Post: 01-12-2008, 08:54 AM
  5. Super X3 spindle controller (by Syil)
    By ints99 in forum Syil Products
    Last Post: 12-10-2006, 11:35 AM
