585,975 active members*
4,612 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > I need an on-line store that is reasonable on metal stock and tools in general
    Jul 2009
    I need an on-line store that is reasonable on metal stock and tools in general that you have used and like.
    I need to gather some more end mills and cutters and also some stock in general.
    Does anyone have a on-line store that they like that is reasonable on metal stock and tools in general? It does not need to be the same store!
    Since I am setting-up my home workshop after moving I need to restock some tools like end mills and cutters and center drills. I also need to stock-up on flat and round stock in small qualities since I live in an apartment!
    Thanks for your help!:wave:
    Brian
    Jun 2007
    92
    Best thing is to go with two sources....one for supplies e.g. Enco or even McMaster-Carr, others are MSC, Travers. The other for supplies, that is if your looking for aluminum, brass or stainless. I've had real good results with Online Metals and a couple others. Do an internet search.
    If you're only requiring small pieces, say a one-foot piece of 6061, 1x4 or 12 x 12 x 1/2, then I'd stick with McMaster. The quality is good and they're really fast.
    Oct 2005
    225
    You can also try speedy metals.
    www.speedymetals.com
    Tommy
    Jan 2008
    48
    if you are just looking to stock up and do not need specifics, there are always good deals eBay... just like anything on eBay you have to know what items are worth or you can end up paying more than from a retailer. In general it seems cutting tools and materials go pretty cheap.
    if you need high precision metal component,you can contact me,thanks.
    Jack
  1. what saw should i use to cut metal stock?
    By yang_cnc in forum Mini Lathe
    Last Post: 08-03-2009, 10:38 PM
  2. Automatic Tools Changer at Reasonable Price
    By Mcyoda in forum DIY CNC Router Table Machines
    Last Post: 03-06-2009, 06:48 PM
  3. Hardware store designed , all metal, Desktop wide router for review
    By FandZ in forum DIY CNC Router Table Machines
    Last Post: 02-10-2009, 02:18 AM
  4. Where do you get your metal stock?
    By svarzaru in forum Benchtop Machines
    Last Post: 05-22-2008, 04:09 AM
