we do alot of 1/4 - 1" beveling on our parts. I usuall just use the chamfer operation, then go to "sequence" and open up that operation. click on "profiling" and edit that. so if i had a .5 break edge on a 1" thick part. i would put my "XY offset" to -.05. under "depth" tab i would set my depth to -.6 to make sure there is no step at the bottom of the chamfer. "cut increment" to .25 because that is the most i can get out of my chamfer mill. and last i click on the "contouring" tab and put 45 (assuming it is a 45 deg chamfer) in the "draft angle" box.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten.”
