im not familiar with HAAS control i get all tool# in 0.000 when i press origin how do i set one tool on 0.000
Val
Val
To zero one tool in the offset page move the cursor to highlight the entry you want to zero, type 0 and press F1.
thanks geof
i got the tool # 0.000 then i press the Z face measure on my 2nd tool# (VNMG) and im getting an alarm of 316 overange when i run the program
all used tools needs to be measured to run or simulate the program , and the zero point needs also to be set up - when not you will get the over travel range error.
i cant get my 2nd tool (VNMG) to Z0. measure..when i press Z face measure the Z value is -216.767 / -357.065 overrange
