585,992 active members*
5,238 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Is there someone with a shopbot around?
    Jun 2003
    114
    I want to build a shopbot clon and I´ll appreciate if someone that has a shopbot (www.shopbottools.com) could answer some questions about diemnsions and sizeing of the machine. My doubts are:
    1. size and gauge of the angles used for the rais
    2. size and gauge of the parts used on the gantry
    3. specs of the step motors (are they the same on the 3 axis)
    4. size of the vee bearings
    5. size of the rack and pinion used
    Thanks for any help...
    Regards,
    Hector
    Jan 2006
    2985
    my dad has a shopbot.
    i can get you all this info around tomorrow or so the next time i go home.
    what i know for now:
    Angle is i believe 1.5x1.5x3/16? the top surface the bearings ride on has been milled/surfaced/or somehow ground.
    the main rails of the gantry are 3x3 box i believe.
    Pretty sure all the steppers are the same.
    the vee bearings are same as these
    item number 3672K11 at www.mcmaster.com
    rack and pinion not sure but can find out.
    Matt
    Mar 2005
    339
    I have a question: Are there other routers (commercial) like shopbot besides ez-router? I mean the same solution/construction? If, YES, could you tell me which one?
    Thank you,
    Zoltan
    May 2005
    674
    I haven't seen any other than the EZ, but I can tell you that the EZ is a crappy clone. The rails aren't ground to a V (creating pressure points), and I highly doubt they're hardened. What this all amounts to is the V-rollers will more than likely wear down the rails unevenly over time, causing Z-axis irregularily when you traverse across the X.
    Mar 2005
    339
    Thank you. I read in several places on net about several clones of shopbot, but without exact indication and never seen others than ez-router. Still curious if there are others (commercial type).
    Zoltan
  1. Stepper control software suggestions
    By jlawren6 in forum Uncategorised CAM Discussion
    Last Post: 05-21-2011, 11:42 AM
  2. Wood router, suitable spindle drive like shopbot?
    By GalaticDan in forum Commercial CNC Wood Routers
    Last Post: 06-09-2005, 05:32 PM
  3. shopbot tools with gecko 340
    By najnielkp in forum Gecko Drives
    Last Post: 02-21-2005, 02:15 PM
  4. shopbot tools controller
    By najnielkp in forum DIY CNC Router Table Machines
    Last Post: 02-09-2005, 08:42 PM
  5. *NEW* Alpha-step steppers and Shopbot (See Video)
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 03:17 PM
