585,997 active members*
5,068 visitors online*
IndustryArena Forum > CAD Software > Autodesk > AutoCAD 2000 to AutoCAD LT 2010?
    Feb 2007
    11
    I'm in need of a CAD upgrade. I've been using 2000 since it came out and have never needed to upgrade. I don't draw in 3D and I don't need modeling. 2000 has worked well, despite some bugs. Now that both my computers are running Vista (one 32bit one 64bit) I can only run it on one machine. I can't print, help isn't functional, and there's a few other fun eccentricities.
    So, time to upgrade a decade... This time around money is tighter than ever. I don't need the most amazing CAD package in the world. The 3D modeling happens in my head. I use the program for basic design and export DXF files to my CAM program.
    Is there anything 2010 LT won't do that 2000 does?
    Thoughts?
    Evan
    Not familiar with 2010, but as long as you don't need 3D, mostly what you lose is customization ability with lisp and vba. If you don't use those either, then you'll probably gain functionality.
    Mar 2004
    1806
    before I retired, we use 2000 at work also. now that I have cnc at home, I use the freeware version that can be found at http://www.progecad.com/
    works just like 2000 and you can't beat the price!
    Art
    AKA Country Bubba (Older Than Dirt)
  1. Autocad 2000 Move
    By N4NV in forum Autodesk
    Last Post: 03-23-2014, 03:30 AM
  2. hoto Autocad 2000 to Gcode NOOB
    By nikodell in forum Autodesk
    Last Post: 09-16-2009, 06:13 PM
  3. Importing 3D from AutoCAD 2000
    By noisillator in forum Uncategorised CAM Discussion
    Last Post: 06-19-2009, 03:44 AM
  4. AutoCad 2000 DXF Question
    By Holmes_ca in forum Autodesk
    Last Post: 01-20-2005, 12:50 AM
  5. AutoCad 2000 Missing .dll file
    By E-Stop in forum Autodesk
    Last Post: 05-30-2003, 05:43 PM
