I was asked in another thread to post a photo of my column brace. Makes more sense to make a new thread for it.
1/8" thick mild steel bolted to the column and the base. SPacers needed on base bolts. Column can be tilted by removing two upper bolts.
Without this brace, I coulnd barely cut aluminum with a 1/4" endmill. With the brace, I can run a 4" diameter fly cutter as seen in this video.
Note: fly cutters typically are making interrupted cuts. This can shatter the plastic gears in a stock X2 head. I would not reccomend this without the belt drive conversion.
"http://www.youtube.com/watch?v=8y-C59aF-ac"]YouTube - Machining Aluminum with Fly Cutter on X2 with Mach3 control software
