585,717 active members*
4,139 visitors online*
    May 2008
    Spindle orientation
    We have a VF4 (1996). Does anyone know if it has spindle orientation. Would like to put on a 90 Deg. head and was wondering if I could orientate it to a certain deg. other than the home orientation.
    2932
    My guess is no. When you orient the spindle with M19, it engages a pin into a cam at the top of the spindle.
    Sep 2006
    48
    Command the following in MDI:
    M19;
    M19 P90.;
    M30
    The spindle should rotate the drive lugs parallel to X axis, then if you have the "Option" it will rotate 90 degrees from that position. If you do not have the "Option" it will stay at the first position or "Not Available" will pop up on your screen.
    Loose Nut
    Jul 2005
    12177
    Quote Originally Posted by jrogus View Post
    The 90 degree head has to be located by a pin in a block bolted to the end of the spindle housing. Spindle orientation has no effect on the position of the 90 degree head, but many of them can be adjusted to almost any angle relative to the X Y directions, only not under program control it has to be set and locked.
  1. Have no spindle orientation
    By plofkop in forum Okuma
    Last Post: 04-05-2010, 09:47 AM
  2. Spindle Orientation
    By JIMMY in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2008, 05:15 PM
  3. Spindle orientation
    By StampCraft in forum Haas Mills
    Last Post: 11-11-2007, 12:31 AM
  4. Spindle orientation
    By jimecv in forum Daewoo/Doosan
    Last Post: 11-09-2007, 06:25 PM
  5. 16i / 18i Spindle Orientation...
    By Sump Cleaner in forum Fanuc
    Last Post: 09-11-2007, 01:46 PM
