I've worked with many applications that were unstable or lacked rigidity so for me It really doesn't matter what type of machine it is , it's a matter of setting it up in a way to use the machine to it's fullest potential , programming tooling and fixturing are the keys to success along with other factors such as chip evacuation . I fully understand the lack of rigidity and power in the small mills and chatter absolutely destroys tooling , the variable mills are designed to reduce or eliminate chatter , they out run regular end mills ten fold at far more aggressive speeds and feeds ,doc , and engagement . they are far more beefy and are less prone to shock that standard end mills
to give an example of how these types of tools can run , I decided to test toroidal toolpaths on mild steel with a CGS variable that I had on the shelf
http://cnctoybox.com/shop/category_7...aram=cid%3D%26 , two things that I wanted to prove was that those types of toolpaths don't need a lot of torque and that a
guy can run steel on a wood router if it is done right even though everyone believed it couldn't be done , so I turned to my router table which I designed for wood or light aluminum cuts which is by no means anywhere near as rigid as a Tormach mill , the wood router spins at 25000 rpm so I started off slow then bumped it up to 120ipm , the cut was good and after a number of passes the tool is in the same state as it was when I pulled it out of the tube
tooling and setup
is what will make or break a guy
YouTube - cutting steel
