hello had a few question, what format does mach need for its g code, i know you need spec the units selected etc... but diffferent software packges
out put there g code in different formats. what is the most common format that mach 3 likes?
I asumming that some formats may be longer ( in lines of code)
im using the demo version of mach ... can someone pls tell me what the upper
limit is in mach.. is it 500... and it its bigger what happens it stopps then cant run pass 500?
