585,888 active members*
4,163 visitors online*
    Oct 2007
    152
    Base table out off square
    Hi, I have a problem with my base table being out of square by .563 inches, what I was thinking to solve this problem was cutting two opposite corners and my question is should I cut on the inside or outside corners of the of the longest diagonal and weld it back up. In the drawing the slant is exaggerated for it to be clearer.
    Thank you
    Apr 2007
    1955
    Just MHO, but no matter what you do, it will never be perfect, so the real question is - how close is good enough?
    I don't know how firmly your table is welded up now, but perhaps you can get it within an acceptable range by sort of pulling it into shape. If you put some aircraft or similar steel wire diagonal into the table (same location as the dimension arrows of your drawing) with a strong turnbuckle, it might be possible to stress it "close enough".
    Be careful with cable wire though - if it breaks, it will do serious damage. I suppose a long piece of threaded rod could be used similarly.
  1. Any Ideas on a Low-Cost Metal Base Table?
    By billman in forum DIY CNC Router Table Machines
    Last Post: 04-13-2008, 06:49 PM
  2. Pics of my metal cnc table (base w/rails complete)
    By guru_florida in forum DIY CNC Router Table Machines
    Last Post: 12-14-2007, 12:12 PM
  3. New controller for an H-Square Table
    By albyrne in forum CNC Machine Related Electronics
    Last Post: 08-30-2007, 06:52 PM
  4. An IH build, base to table
    By ozzie34231 in forum Charter Oak Automation Support Forum
    Last Post: 05-31-2007, 11:05 PM
  5. Mini mill base/xy table question
    By akraven in forum Benchtop Machines
    Last Post: 11-13-2006, 08:25 PM
