585,761 active members*
4,080 visitors online*
    Sep 2004
    80
    pick and place controller design
    Any ideas on what is the easiest way for a diyer to control a pick and place arm custom built for one job only? 2 axis of motion, y travel 45 inches, z travel 3 inches. Any ideas for a standalone system/controller solution?? Could one of the pic boards be adapted to hold a simple motion program on board??
    24220
    If this is just a simple dedicated system, You pick up one of the stand-alone motion controllers like this one, http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW programmable in simple two letter commands. program with any PC through the serial port, PC not required to run it.
    Al
    Albert E.
    Mar 2004
    500
    Can a DIY use a flash memory of some sort to do this with a hobby cnc controller?
    Thanks.
  1. SMD pick and place
    By ciccio in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-13-2019, 12:56 PM
