585,585 active members*
4,313 visitors online*
    Jul 2009
    25
    Resetting Machine Zero
    We recently had our Z axis encoder rebuilt on our Miyano TSV-C37 which uses a Yasnac i80M controller. Does anyone know how I would go about resetting machine zero for the Z axis? Since we reinstalled the motor and encoder, it's way off. Specific or generic advice are both welcome.
    Thanks in advance.
    Mar 2004
    1542
    Generic-
    machines home by finding a home limit switch. Then switching to look for an index mark on the encoder. If you're off more than one screw revolution, look to the switch. Less than 1, rotate the encoder by lossening the coupler connection.
    Karl
    Jun 2008
    1511
    Quote Originally Posted by Karl_T View Post
    Generic-
    Karl
    That will get you close. Is it then up to the gridshift parameters to fine tune the position?
    Stevo
    Jul 2009
    25
    Thanks for the help. I got it sorted out.
    Jun 2008
    1511
    Share the info. What did you have to do to fix it? This will help if someone else has the same issue and comes across this thread during a search.
    Stevo
  1. SL 15 Parameter resetting
    By MILLMANM in forum Mori Seiki lathes
    Last Post: 10-08-2008, 04:01 PM
  2. Resetting X0 Y0 Z0.
    By Witsenburg in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2007, 03:39 PM
  3. Mach keeps resetting
    By Moondog in forum Machines running Mach Software
    Last Post: 08-16-2006, 01:57 AM
  4. Zero location resetting mid-run
    By esmiller in forum Machines running Mach Software
    Last Post: 03-03-2006, 09:00 PM
  5. resetting fields
    By hogman in forum GibbsCAM
    Last Post: 05-06-2005, 02:22 AM
