585,992 active members*
5,795 visitors online*
Page 3 of 3 123
Results 41 to 54 of 54
  1. #41
    May 2009
    393
    Need Help
    Hi...
    Thanks for the Reply, but #3 did not make any difference. The alarm still exists.
    Need Help..
    Ash
  2. #42
    Feb 2006
    1792
    Check if you have typed the program correctly. I cannot see any error in the program.
    #4 and #5 are local variables of the macro. So, you can see their values when the macro is being executed. These remain undefined in the calling program.
  3. #43
    May 2009
    393
    Hi
    Hi
    I will make sure that the Program has been Typed Correctly.
    Also wanna Ask that will it output the Variable value or it will also output the Identification of Values..
    Just like -
    123.456
    456.123
    or
    #101 = 123.456
    #102 = 456.123
    What alteration in the program has to be done if i want a Output with Idenfication...
    Ash
    Thanks for your TIME, SUPPORT & PATIENCE
  4. #44
    Feb 2006
    1792
    DPRINT[VAR#3[50] ***DATA#2 [53]] would print as
    VAR 101 DATA 123.456
    etc., when parameter 6001#1 is 0. When it is 1, the output would be
    VAR101 DATA123.456
    (Make correction in the DPRINT command)
  5. #45
    May 2009
    393
    DO - DO
    Really this was a Format Error. Actually it is Supposed to be ( D - OHO - ONE ) & not ( DO - ZERO - ONE ) & i had typed it as D - Zero - 1.
    Sir Mike Lynch told me the Soution for the same & the command executed sucessfully.
    :wee::banana:
    Ash
  6. #46
    Oct 2009
    12
    Hi all,
    I have need standerd value of G56 for macro. Just like G65 H___P__Q__R__. please send me th chart of H,P,Qand R value thanks
  7. #47
    May 2009
    393
    Hi
    U can check it out with in Macro programming manual that came with the machine.
    Unless give me some time & i will check it out & ping you back.
    Ash
  8. #48
    Feb 2006
    1792
    Is this what you need?
    A...........#1
    B........... #2
    C...........#3
    D...........#7
    E........... #8
    F........... #9
    H...........#11
    I........... #4
    J........... #5
    K........... #6
    M...........#13
    Q...........#17
    R...........#18
    S...........#19
    T...........#20
    U...........#21
    V...........#22
    W...........#23
    X...........#24
    Y...........#25
    Z...........#26
  9. #49
    Jun 2008
    1511
    Quote Originally Posted by g-codeguy View Post
    Stevo, you're the man! Guys like you make me proud to be a machinist.
    Thanks Dale.......:cheers:
    Stevo
  10. #50
    May 2009
    393
    WHILE - DO Loop
    hI Guys,
    As we discussed Previously about WHILE-DO loop option, there is also 1 minute correction to it. It goes as follows -
    DPRNT [VAR3 [5] ***DATA#2 [ 57] ]..........This is the format as specifed in that program,
    BUT ACTUALLY It should be -
    DPRNT [VAR3 [50]***DATA#2 [57 ] ] .
    Format errors encounters if u only command [5] instead of [50].
    Ash
  11. #51
    May 2007
    1003
    Nt
  12. #52
    May 2009
    393
    Cool Verified
    I have tested that error & debugged it on my machine.
    The error resides in the format.
    Ash.
  13. #53
    Feb 2009
    64
    Format
    I'll look into that format change when I get back into the shop. I ran it as is, VAR3[5], without any errors so far. It may just be how my control interperets the numbers in the brackets. Standard format includes 2 numbers (the second number to denote accuracy following the decimal), I believed mine was reading [5] to mean there was an implicit 0 following the 5. I ran this using Hyperterminal to capturethe text file, I will see what difference the format change has on mycontrol (which is HAAS i this instance).
    Quote Originally Posted by Ashish B View Post
    hI Guys,
    Ash
  14. #54
    Nov 2008
    43
    hi james, my name is rosalio moreno im from grand junction colorado i work for lewis engineering and i am wonder if you can help me out with some macro information, im struggling with a 3 point vector macro and i really need help
    thankss
Page 3 of 3 123
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  3. Program Restart in mid program?
    By Donkey Hotey in forum Haas Lathes
    Last Post: 03-18-2008, 08:19 PM
  4. Need a CAM program
    By SteveD in forum Community Club House
    Last Post: 09-28-2006, 07:46 PM
  5. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
