I dialed in the probe stylus 3 times today and each time I check it, its off again
yesterday, the machine alarmed out in the middle of a toolchange due to low air pressure
The probe was in the ATC pocket and during the recovery process it dropped to the floor. The stylus broke and when I installed a new one and calibrated it, this problem started.
Other than this calibration problem, the probe is working perfect with no visible damage or sloppy loose-ness anywhere
something else that may or may not be related:
the spindle is leaking air
you can hear it and feel it whether theres a tool in the spindle or not
the air is leaking directly out through the spindle taper
this was noticed 1st just today, just like the probe problem
