584,837 active members*
5,293 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Floppy drive hack?
    Does anyone know of something I could replace the floppy drive with so I'd have more memory potential. Optimally, I'd like to use a USB stick and then DNC off of that.
    I know I can DNC from another computer and trickle feed, but I'd rather not have to do that.
    We have a VF zero and VF2 that are around 7 years old.
    Why do CNC machines have to be such a pain in the ass when it comes to memory. They should all come with a gazillion gigs of memory. My frickin phone has 32 gigs. Come on now.
    4826
    First you get good, then you get fast. Then grouchiness sets in.
    Looks perfect, thanks Hu!
    Boss is ordering one today.
    JW
    Apr 2008
    1577
    Nice link HFD. I'ma try one in my Fadal. Many thanks.
    4826
    John,
    Let us know how it works for you. I've wondered how the Haas would handle files that are bigger than should logically fit on a floppy drive, and whether you'd have to break them down or not.
    Haas
    Yes, that would be really nice if it would work with the older HAAS equipment with the 3.5 floppy drives.
    I would also be interested in feedback from anyone that tries it on HAAS equipment.
    I have recently looked at some older HAAS CNC lathes with the 3.5 floppy drives. I like the USB port on my 2007 HAAS TM-1P and this upgrade path would be nice if it works.
    John
    Dec 2008
    3110
    Here's another one calmotion
    We investigated for an Okuma machine, but found it was not suitable ( still had to purchace the DNC option for the machine )
    Quote Originally Posted by HuFlungDung View Post
    Got it installed today and to my surprise, it worked perfectly without ANY messing around. I loaded a program just like I would off a floppy, no problem. I also DNC'ed and it worked just like it should. I didn't get a chance to try DNC-ing a large file yet. I think it will work since the control works it's way through the code while only buffering a small portion. Just like using RS232
    Thanks Hu!
    (Instruction on how to DNC from the floppy are in the manual.)
    4826
    Its good to know it worked out okay.
    Sep 2005
    47
    When i read the instructions for that unit, it specifically said you cannot exceed 1.44mb for a folder to emulate as a floppy. If you can actually DNC from a larger than 1.44mb file, please post a reply! thanks!
    Quote Originally Posted by xiondavis View Post
    I remember reading that too and it must be why I can't DNC the 4 meg file I just tested.
    Still better than using retarded floppies. Way faster.
    JW
    4826
    I've had zero experience with doing the DNC on the Haas so I don't know what is legal and what isn't. But could you write sub program calls in a main program on the control and somehow have it jump to various folders on the floppy, supposing that each folder has 1.44 megs worth of a much larger program that you split up?
    Interesting idea hu. That may very well work. Would be a pain break up a program and sub it out. I think I'd rather just Dnc off another computer.
    Silly that we need to do any of this crap. CNC has to stay about 20 years behind current tech. Rs232 should be illegal. Invented in about 1960. We have around 2 megs of memory in our haas, give me a break, should be gigs.
    Thanks,
    JW
    Sep 2007
    20
    i don't remember reading if anyone tried and tested on a HAAS CNC? i have 2 vf-4's that i would desperately love to upgrade. half the time the floppies don't work
    Quote Originally Posted by Ford25 View Post
    Yes, I tested it on my Haas and it works perfectly. Only thing I couldn't do was DNC a large file. Pop in the usb stick and it acts just like a floppy, no difference.
    Aug 2009
    18
    Got mine yesterday and installed. Worked fine after i turned the ribbon cable over (thanks for the help on that John). Loads and downloads files exactly as floppy.
    Aug 2009
    18
    And I installed it on a 1997 VF2
    Aug 2004
    309
    Im surprised the koreans or chinese dont have something similar out for $29
    Sep 2005
    47
    The drive adapter IS chinese. I'm sure that the only reason its not $29 is lack of demand, gotta make some money somewhere - probably costs $13 in materials.
    Oct 2009
Page 1 of 2 12
  1. DNC from floppy drive
    By jwknow in forum Haas Mills
    Last Post: 03-11-2010, 03:39 PM
  2. Floppy drive alternative
    By rbever36 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2009, 12:46 AM
  3. Haas TM-1 Floppy drive
    By speedrider in forum Haas Mills
    Last Post: 05-13-2009, 06:45 PM
  4. Floppy Drive
    By advt001 in forum Cincinnati CNC
    Last Post: 10-12-2008, 03:35 AM
  5. Has anyone tried a Floppy drive adapter ?
    By meadowtech in forum Controller & Computer Solutions
    Last Post: 04-18-2008, 10:51 AM
