585,753 active members*
4,194 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > UNKNOWN FAULT CODE
Results 1 to 9 of 9
    Sep 2007
    92
    UNKNOWN FAULT CODE
    hellow fellow OKK users, I got an alarm while running and can not find it in our books anywhere, it gave me PL0011 #2011 "COOLANT UNIT TROUBLED 1" I shut down and rebooted the machine the next day and so far it has run fine?? any clues are greatly appreciated because OKK would not return my phone calls
    Jun 2006
    25
    #2011 alarm
    Look in your electrical manual from OKK. All PLC alarms are in there. Check the filter on your oil coolant unit. It may be getting dirty.
    Sep 2007
    92
    thanks mitsman , filters look good, our OKK rep says it is a phase detect circuit problem so our electrician bypassed it because we know our phasing is corect and that solved the problem untill we can find a replacement component. what type of control so you have? ours is a 635 V
    Jun 2006
    25
    CNC Controls
    For standard Mitsubishi controls we have here at least one of the following: 5000CII, M83, M84, M85, M86, M0, L0, M300, M3, L3, C3, M2, M2A, M500, M50,C5, C6, E60, E68, M60, M64, Magic64, M65, M66, M64S, M65S, M66S, M610, M625, M635, M635V, C70, M70A, M730, M750, M720BM.
    Sep 2007
    92
    are you saying that you have info for the 635V ? if so I would appreciate any PDF documentation, I downloaded the basic operations and programming PDF from the mits website but any "in depth" info on this machine seems hard to come by, thanks
    May 2008
    107
    Dear all.
    Pls. help me. I have an alarm E20 on OKK MHA300( used Meldas 84 controller) when I power on, so my machine can not start. Does any ones can help me to solved this problem.
    Thanks.
    Re: UNKNOWN FAULT CODE
    Dear All.
    I'm currently working on the network I/O application from Citizen. We have 3 Machines with the M-635 nc Unit. I was told that the System is not capable of connecting it to a ethernet network. I't came to my ears a couple month's ago and I don't remember from who anymore, that there is a interface card for this system from a 3rd party available. Can anybody help me out in this case.
    D.K.
    Feb 2005
    28
    Hello to All Friends
    I need your help
    I have a hartford machining center, whitch work with meldas magic64.
    I need system floppys
    Meldas magic64 nc system disk 1 and 2
    Meldas magic utility disk 1 and 2
    Meldas magic meldasmagic monitor disk 1
    Meldas magic custom API library runtime disk 1 and 2
    Meldas magic64 NC data 64m disk 1
    Please help me
    If u have these floppy's please send me a soft copy
    My email. [email protected]
    Thanks in advance
    Feb 2005
    28
    Quote Originally Posted by Kashif View Post
    I need your help
    Please help me
    Thanks in advance
    Mitsubishi Meldas Magic64 PC Based
    System SoftWare Disk
    AOMEI complete disk image
    https://drive.google.com/drive/mobile/folders/1ENcGRNDRlsExITohcSXAEkZUd5pFOblP?usp=sharing
  1. Fanuc 11M Fault Code SR 820 DR OFF (1)
    By wemr449 in forum Fanuc
    Last Post: 04-10-2015, 08:41 PM
  2. Unknown G code
    By cnczoneguy in forum G-Code Programing
    Last Post: 10-26-2012, 05:23 AM
  3. G65... unknown G code?
    By omgtim in forum Fanuc
    Last Post: 04-19-2010, 08:46 PM
  4. Unknown g code G23 error?
    By keaton64 in forum Mach Plasma / Laser
    Last Post: 09-22-2009, 03:33 AM
  5. Fault code
    By Rufan in forum Bridgeport / Hardinge Mills
    Last Post: 09-28-2005, 01:57 AM
