Originally Posted by
microinv
Thank you Stevo, I input the parameter manually. That wasn't a problem since they are not so many. Also Wasino sent me in a form of photocopy too.
Anyway after input the parameter, the machine limits were misplace. I was told to zero it out. However there was a problem on z axis. It moved passing the home position and hit the second limit switch ( the last one that prevents the ram crash to the end of column). After that I can't make machine to move even on the O.T.Release mode.
I've posted this problem in another thread. I hope someone can help me out on this too.
My machine is now able to comunicate through RS232. But every time we loaded the program, after PC show 'transmission successful', the CNC monitor keep showing 'INPUT' and stuck there until we unplugged the cable. Then the program was loaded. So basically it works, only that we have to unplug the cable everytime after the loading process. It was not covenient but I can live with that.
Anyway, thank you again for your help and the information you gave us.
Pao
