585,977 active members*
4,244 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Converting a CNC router into a flatbed printer
Results 1 to 11 of 11
    There are a million and one threads about how an inkjet printer can be hacked into a flatbead printer, and how printers can be converted into basic CNC routers. But I have a slightly different project.
    I want to utilise my CNC router (a Routout CNC Z90) as a flatbed printer. Obviously the mechanics for moving the printhead is all in place, and a holder for the heads can easily be knocked up, but where on earth do I start with the electronics to control when and where the ink is spat out?
    What are the potential obsticles in this project? What are the software requirements and electronic control circuitry that is needed? What about drivers? Any ideas on the subject will be appretiated.
    Regards, Dave
    Apr 2005
    3634
    I'm not sure this is the info your looking for, I thought you might like to see this machine (not mine) it was built by andreas2 a member here on cnczone.
    [ame="http://www.youtube.com/watch?v=J0YDP4QsQus"]YouTube - my first cnc painting machine[/ame]
    More videos here
    The video I posted here is more of cnc painter, remember when you start going to a much larger scale, you will run out of ink fast with the inkjet cartridge ($$).
    Paint might be a better idea?
    Free DXF - vectorink.com
    Apr 2005
    3634
    Here is more info on the machine in the above video
    http://www.cnczone.com/forums/showthread.php?t=35678
    Hi Switcher
    Thankyou for the response & video, but this isn't exactly what I have in mind. I am not looking to have a plotter; I am wanting to use the printhead from a conventional inkjet printer and attach it to my cnc machine in order to get more height on the Z axis.
    The printhead would scan back and forth like it does in a normal printer. This way I can print direct to PCB amongst other things (and do it at speed; an issue that cannot be resolved with a plotter
    Aug 2004
    54
    check out andersonamerica.com/cojet.htm
    Quote Originally Posted by eigstein View Post
    Yeah, that's the type of thing I'm hoping to achieve. Of course I am still aiming to maintain the original functionality of the router; I just want to be able to print as well.
    Apr 2009
    77
    There is Mike Lyon but his is for artistic effect and I think it uses an air brush and has to do multiple passes.
    http://mlyon.com/
    Google open-source print heads, contact your local college computer science dept, you might even find students that would help if they can gain credit for their work. You could try by emailing the depts and having them post for your needs.
    If you have a print head in mind search for hacks on that. I know some of the controllers have been hacked to do frosting for cakes ect.
    May 2006
    32
    These guys did it. They have inkjet printer heads on a cnc machine to print onto 3d cnc cut topgraphic maps. Check out the video here:
    http://www.stm-usa.com/NGS_movie.htm
    Mar 2009
    624
    Quote Originally Posted by billman View Post
    Wow that is very impressive.
    Looks a bit more involved than just a printer hack job thou.?
    May 2006
    32
    They said in the video that they use the same software to cut and fly the print heads over the map. When they say fly is it print as well? Could for example Mach3 be used to print in 3d?
    It would be really cool to do this project. I did post awhile back info on a 3d airbrush printer. If that helps anyone:
    http://www.cnczone.com/forums/showthread.php?t=50945
    May 2006
    32
    This might help too. I found the patents for the topography printer:
    http://www.freepatentsonline.com/res..._range=all&p=1
  1. Building a cnc router with an old printer and an old scanner
    By codemaster in forum Open Source CNC Machine Designs
    Last Post: 09-16-2013, 03:10 AM
  2. Converting a laser printer into a 3d laser printer
    By João Carimo in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2011, 09:56 PM
  3. Converting a cheap printer to a laser engraver for wood
    By thistleguy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2009, 12:46 PM
  4. DIY flatbed printer ?
    By rcpilot82 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-18-2009, 05:25 PM
  5. My hacked HP printer flatbed
    By Graham S in forum CNC Machine Related Electronics
    Last Post: 06-02-2007, 11:31 PM
