586,005 active members*
5,181 visitors online*
    Jan 2007
    435
    MM2/SMM2 dimension needed
    If anyone here has a MM2 or SMM2, I could sure use some help with a dimension. I'm going to be placing this mill with the back of it up against a wall. There is a door on the back of the machine which needs to be accessible. To access the back of the machine I'm going to be putting a door in the wall that it will be backed up against. What I need is the length from the leftmost protrusion of the machine on the left side to the beginning of the door opening on the back of the machine. Once I have this I can cut the hole in the wall for the new door.
    My local HFO can't seem to find this information anywhere. Anyone out there with a machine and a tape measure that could help?
    Sep 2006
    251
    You may also put some thought into a vent in the door. If a vent is not an option, you may want to leave the machine out far enough so that the electronics get plenty of cool air. HEAT SEEMS TO BE THE # 1 CAUSE FOR ELECTRONIC FAILURES. Just something to think about.
    Just a good ol' boy, never meanin' no harm.
    Joe
    Jan 2007
    435
    Thanks, I'll keep that in mind.
  1. Looking for Gerber Dimension 200
    By gio666 in forum Community Club House
    Last Post: 06-01-2008, 03:32 PM
  2. Looking to buy a gerber dimension 200
    By gio666 in forum Canadian Club House
    Last Post: 05-27-2008, 08:39 PM
  3. SL-30 dimension needed
    By rka in forum Haas Lathes
    Last Post: 04-01-2008, 03:24 AM
  4. Changes to Dimension Preference
    By SPEEDRE in forum Solidworks
    Last Post: 02-01-2008, 07:03 PM
  5. Gerber Dimension 200
    By teemac in forum Gerber
    Last Post: 04-22-2007, 05:30 AM
