Hi all,
i need a suitable vacuum pump to hold down 3 separate pieces of hardwood with 36x4,5 inches each. Note that each part will have it`s own vacuum fixture and will be rubber sealed so the vacuum force would be more important than the max airflow.
Cutting depth will be around 1/2 inch max, bit diameter would be between 1/2 and 1 inch max, upcut 2 flute round nose.
So what kind of a vacuum pump (specs) would you suggest for such an application?
Thanks very much for any advice.
