586,024 active members*
4,299 visitors online*
Thread: Deskcnc
    Aug 2009
    Deskcnc
    can deskcnc accept an save two different machine profiles within the program?
    I have two mills with different parameters and would like not to have to change each time each machine is used seperatly.
    Thanks!
    Dec 2004
    1865
    Quote Originally Posted by pfiat View Post
    can Deskcnc accept an save two different machine profiles within the program?
    I have two mills with different parameters and would like not to have to change each time each machine is used separately.
    Thanks!
    I don't think so but I am pretty sure you can install Deskcnc on your machine in 2 different places and then run which ever one you need.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. DeskCNC
    By cncadmin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2013, 09:37 PM
  2. deskcnc
    By natchez in forum DeskCNC Controller Board
    Last Post: 01-02-2006, 09:57 PM
  3. Need help with deskcnc
    By BUD B in forum Uncategorised CAM Discussion
    Last Post: 12-31-2005, 01:49 PM
  4. DeskCNC
    By wmgeorge in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-01-2005, 12:55 AM
  5. Deskcnc bug
    Last Post: 01-10-2005, 05:08 PM
