585,560 active members*
3,350 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Approach in contour or profile cuts
    Aug 2009
    25
    Well, I'm definitely a newbie again.
    I have a pocket that I would like to cut out by simply running a contour around the inner walls -there will be a little island in the middle, which will fall out when I'm done, but if I use the roughing cycle/operation, EdgeCAM puts in these little swirl moves - without them the program is shorter by a minute or two - serious time when you think about a couple of hundred runs.
    However, if I use a profile cycle/operation, there is no option for a ramp entry. How do I cut a contour with a ramped entry?
    Sep 2009
    19
    On your profile page go to the lead tab and select the type to vertical then you can adjust the lead in radius or change it to a angle and a set length and over ride the feed rate if you need to.
    Aug 2009
    25
    Thank you - that was a great help. Now I have another problem.
    On the first two passes, nice ramp approach. On the last pass - plunge.
    Also, I have to specify both an angle and a length - is there a way to make the program do whatever length is necessary - along a curve or whatever, without doing the trig to figure out the length of the approach?
    It's a 2d continuous arc loop with 4 radii, if that matters.
    Sep 2009
    19
    try changing the value in the links tab for your short link distance to stop the plunge feed on the last cut, and i dont know of any other way for the for the link appproach to be inserted.
  1. How to profile/contour and avoid areas?
    By Shepard in forum Mastercam
    Last Post: 12-04-2007, 12:11 AM
  2. frustration....plasma cuts off during cuts any ideas?
    By gpnjuice in forum Waterjet General Topics
    Last Post: 11-19-2007, 01:45 AM
  3. Issue w/ Boss9 Post - Contour Cuts
    By StickShifter in forum Post Processors for MC
    Last Post: 01-17-2006, 02:10 PM
  4. contour profile
    By stevieboy in forum Mastercam
    Last Post: 10-15-2003, 07:40 PM
