Not seen this problem reported in any searches. Basically I can trip out the motor overcurrent circuit on my X2 by lightly gripping the spindle while it is rotating - or speeding up too quickly. Certainly, there isn't enough torque available to do any cutting. This happened after I had a trip event while cutting heavily with heavily worn motor brushes. The heavy cutting pushed the motor over the edge and there was a lot of arcing followed by the motor tripping out. I took out the brushes to find them almost non-existent and the springs were brittle and cracked up from the heat.
I replaced the brushes with new ones but now I have this easy tripping problem. There's nothing binding up the transmission, and I can't see any debris around the commutator when I opened it up. The comm was worn quite a bit and I cleaned the surface of it a bit to improve the contact with the brushes, no effect though. Maybe there's a component in the speed controller that could be damaged causing this fault? Help would be much appreciated! I need to cut parts pretty soon.
