585,926 active members*
3,519 visitors online*
Thread: Boring Head
Results 1 to 9 of 9
    Jan 2007
    435
    Boring Head
    Anyone have any suggestions for a good boring head? Standard Criterion or one of the modular systems? I anticipate boring up to 3" diameter holes.
    Jul 2007
    16
    If you were in the UK I could recommend a BH from www.rdgtools.co.uk. The 3" R8 boring head ( If have a bridgeport ) is excellent. I have just been boring some holes for needle roller casings and had to achieve a tolerance of +- 0.5 thou. The 3/4" bar capacity gives good stiffness. They do ship overseas and they are very cheap, mine was £45. It is of far eastern/oreast european origin but the quality and finish is superb for the money.
    Hope this helps.
    Jan 2007
    22
    Pinzbohr boring heads from iscar.
    http://www.pinzbohr.com/ingles.htm
    Cheers.
    Nov 2008
    129
    Boring heads
    If it precision head you require I would look at Komet as the they make their own heads & inserts to suit boring application
    Alan
    http://www.mctooling.com/category/34...ing-Heads.html
    Jul 2009
    5
    boring heads
    You can use the WOHLHAUPTER sistem, have a lot of options and working very well on roughing and finishing operations. you can check some examples in website: www.wohlhaupter.de
    Jan 2007
    435
    Thanks for the advice on this. I'll check them out.
    Aug 2006
    5
    Iscar and D'Andrea, they are the same. I believe Maritool has an offshore version as well.
    Jan 2008
    35
    Kaiser all the way.
    Genuine Swiss Precision.
    >>>>>>>>>> Made In England <<<<<<<<<<
    May 2009
    12
    i use D'andrea on bothe the manual machine and the maching center they are top notch can't fault em, there collet chucks are also great quality and cheaper then taiwan or china made chucks of lesser quality
  1. d'Andrea boring head
    By deckerdesign in forum Want To Buy...Need help!
    Last Post: 09-09-2009, 02:11 AM
  2. Boring head help!!
    By wrechin2 in forum MetalWork Discussion
    Last Post: 03-18-2009, 05:51 PM
  3. Boring Head
    By artin51 in forum MetalWork Discussion
    Last Post: 07-10-2008, 11:12 PM
  4. What Boring head should I go with for CNC?
    By SchurrPower in forum MetalWork Discussion
    Last Post: 03-10-2008, 11:07 PM
