585,763 active members*
4,232 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > FAGOR 8055M MASTERCAM V8 POST
    Sep 2009
    Post FAGOR 8055M MASTERCAM V8 POST
    HI THERE!
    I'M WORKING WITH MASTERCAM V8 WITH A FAGOR 8055M COMMAND. WITH THIS GENERAL POST I CAN'T PROGRAMMING DRILLS TO THIS COMMAND BECAUSE THE LETTERS DOESN'T MATCH WITH THE DEFINED CYCLES, FOR EXAMPLE I HAVE TO HAVE A CYCLE LIKE THIS: G69 G99 Z5 I B
    Z= SECURE DISTANCE
    I= DEPTH
    B=peck,
    BUT WHEN I USE THIS POST INSTEAD OF "I" APPEARS "Z".
    I NEED YOUR HELP TO FIND ONE GOOD SOLUTION!!! THANKS!
    Jul 2008
    67
    Quote Originally Posted by NIKEIME View Post
    HI THERE!
    Z= SECURE DISTANCE
    I= DEPTH
    B=peck,
    What I can tell you is that Mastercam has a good working post for the Fagor CNC here in the USA, I assume this is available for overseas too. Talk to your local Mastercam dealer.
    Hope this kind of helps.
    (As a side note, you can also program this cycle in a conversational-type automatic method at the CNC..... for example, simply key in the G81 command and press the "help" key and it'll prompt up a graphical picture and fill in the blank programming)
    Aug 2012
    We use YPV-100B (13S-75) AC Servo drive for plano milling machine.Now it get alarm N0.4,Over Heat.But not the motor fault.If we change this drive & test with another drive ,the whole machine is good, can operate well.How can we change/correct temperature setting of this AC drive.
  1. Mastercam post for Fagor 8055M
    By jaangi in forum Post Processors for MC
    Last Post: 01-09-2022, 02:48 PM
  2. FAGOR 8055M post-processor
    By Aionerv in forum BobCad-Cam
    Last Post: 02-06-2013, 08:21 PM
  3. Drive Error with Fagor 8055M
    By Kiwi in forum Fagor Automation
    Last Post: 08-06-2012, 09:53 AM
  4. Fagor 8055m and renishaw sp2-1
    By mwyss in forum Fagor Automation
    Last Post: 05-13-2011, 10:44 PM
