585,997 active members*
5,110 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Feb 2007
    314
    need to replace spindle encoder
    machine: hardinge vmc 1000
    control: fanuc 0-MD
    spindle encoder: sumtak lhe-428 1024
    I get spindle alarm 47 (Detects incorrect position coder signal count operation) I need to replace encoder but this model is discontinued. I'm looking to replace by another model but how can i be sure that it is compatible?
    Oct 2008
    106
    The one I offer you this morning will work for your machine. guarantee
    Ahn Vuong
    Feb 2007
    314
    thank a lot, i propably order to you in few day, is it realy a sumtak lhe-428 1024 or a compatible one? I'm not very familiar with that stuff, for connector, i just have to put same color of wire at the same position than the old one and it will work?
    24221
    Is this a shaft encoder or through-hole?
    You will find a replacement either at Renco or Hengstler, Koyo are also a low cost resource.
    5vdc 1024 line differential should work OK.
    BTW, Sumtak were taken over by Renco, now heidenhain own Renco.
    Al.
    Albert E.
    Feb 2007
    314
    it's a bore style encoder but the hole is not through.
    24221
    Here is a Renco they are dumping these new/old models, ebay # 200369969848 $90.00
    It is 1024 with a 1/2" shaft size, the cables are tricky to make up so if you go for it, get them to supply a cable.
    Al.
    Albert E.
    Feb 2007
    314
    how can i do to know each wire function. there is 9 wire. i think it is:
    A
    not A
    B
    not B
    Z
    not Z
    Vcc
    0V
    but wath is the last wire and how to know the color of each of them?
    24221
    You will most likely have a shield as the 9th wire.
    The Sumtak info I have for the LHE series is:
    White +5v
    Black 0v
    Red A
    Pink /A
    Olive B
    Blue /B
    Yellow Z
    Orange /Z
    shield
    They are almost identical to the Renco style on ebay right now.
    Al.
    Albert E.
    Feb 2007
    314
    shield is on the green and there is a withe wire
    Dec 2008
    239
    connect the A B strobe wire and VCC and GND if any feed Back connection is there connect that also
    Cable for connecting
    between the main When a built–in
    When a separate pulse coder or
    linear scale is used
    CPU board to the
    servo amplifier
    pulse coder is used
    Feedback cable
    connected to the motor
    Cable connected to the
    1st axis AMP1 ENC1 ENC1 SCALE1
    2nd axis AMP2 ENC2 ENC2 SCALE2
    3rd axis AMP3 ENC3 ENC3 SCALE3
    4th axis AMP4 ENC4 ENC4 SCALE4
    Dec 2008
    239
    The SIgnal Details are as : TLML
    TLMH
    CTH1
    CTH2
    SRV
    SFR
    ORCM
    MRDY
    ARST
    *ESP
    Torque limit command (low)
    Torque limit command (high)
    Gear signal 1
    Gear signal 2
    Spindle reverse rotation
    Spindle forward rotation
    Spindle orientation
    Machine ready
    Alarm reset signal
    Emergency stop
    SPSL
    MCFN
    SOCN
    RSL
    RCH
    INDX
    ROTA
    NRRO
    INTG
    DEFM
    Spindle selection signal
    Power line switching
    Soft start/stop cancel
    Output switching request
    Power line state confirm
    Orientation stop pos. change
    Rotation direction of ORCM
    Short-cut of ORCM
    Speed integral control signal
    Referential mode command
    24221
    I took the LHE info from the Sumtak catalogue and it shows the white wire as 5+.
    Do you have 9 wires counting the shield?
    Al.
    Albert E.
    Feb 2007
    314
    yes 9 counting the shield and your info seems to match with my encoder. Can i use a diferent ppr encoder and just change a prm?
    24221
    I would think it would be changeable, but a brief look through the parameters did not show it, just the spindle gear ratio's.
    Al.
    Albert E.
    Feb 2007
    314
    finally i choose the low cost option and bought a koyo encoder (TRDA-VA1024V8-40-ABZ). I hope i make a good choice. Like i said, i'm not familiar with this stuff but i'm confident that i will succeed.
    Thanks to evrybody
    24221
    Hopefully these are 5v differential as suggested in post #4, some are single ended or open collector.
    I could not see the specs for the one you selected on the site?
    Al.
    Albert E.
    Oct 2008
    106
    Hi Samu,
    If the Koyo one you purchase doesn't work make sure to contact us. by the way you may want to know the parameter for Spindle orientation position, if the position is off you can change the parameter 6577, either increase or decrease the value
    Ahn Vuong
    Feb 2007
    314
    Quote Originally Posted by avtechmachine View Post
    Hi Samu,
    Ahn Vuong
    Be sure that if it doesnt works i`ll think to you. Hope that i will not loose money trying to save some!
    Al,
    in the spec they say that output circuit is line driver output 26C31 compatible. Good thing or not?
    24221
    That should be OK.
    Al.
    Albert E.
    Sumtak msk 015 1024
    Sorry to hijack thgis thread but since I kind of have the same problem probably I can get helped easier.
    I need to replace a magnetic encoder SUMTAK MSK 015 1024. Do I have any options? This one is obsolete and the ones they have in ebay they are US$2,000
    The lathe machine is a hardinge conquest 42, right now I can not remember the fanuc control it has.
    jolulank
Page 1 of 2 12
  1. E32 encoder replace
    By tech5028 in forum CNC Swiss Screw Machines
    Last Post: 06-24-2008, 10:31 AM
  2. Spindle encoder
    By Mark Hockett in forum Fadal
    Last Post: 03-17-2008, 09:27 PM
  3. replace spindle on Series2 r2e3 for Autotoolchange
    By cut more in forum Bridgeport / Hardinge Mills
    Last Post: 11-21-2007, 06:56 PM
  4. In need of a spindle to replace PC892
    By spoiledbrat in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 10-10-2007, 08:44 PM
  5. spindle encoder
    By heilcnc in forum LinuxCNC (formerly EMC2)
    Last Post: 09-10-2007, 03:12 PM
