585,715 active members*
3,994 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Need Help with rs232 connection LB-15
Results 1 to 11 of 11
    Oct 2008
    105
    I am trying to connect a pc to my LB-15. I assumed that a standard parallel printer cable hooked up to the serial connection and the pc would work, but when I did it it overloaded something in the control and shut it down. It didnt tear anything up, but I still need to connect my computer to it. I have seen a picture that has a second cable in line before it reaches the computer and I feel like there is magic in the intermediate cable. I am attaching a copy of the picture. Please help me understand the connection. Thanks.
    Dec 2008
    3109
    read this thread
    especially about the cable wiring --- it is NOT a standard printer cable
    Feb 2009
    6028
    RS232
    Um, bad news. If it shut down the control when you plugged something in, You most likely smoked the RS232 board. Okuma's are VERY sensitive to this. You will need a light box to check the port now. If you do get it working, DO NOT UNPLUG/Plug the cable in with the power on.
    Oct 2008
    105
    Anyone curious of the outcome of this...with the correct cable, everything is up and running properly. No damage to RS232 board. Much easier than I assumed. I have the parameter changes necessary as well as the Pin-Out mapping if anyone needs. Thanks as always for the help.
    Sep 2009
    25
    What pin-out did you use to configure the cable? I asume you are not working DNC.
    Oct 2008
    105
    Here is the information.
    Attached Files Attached Files
    Mar 2011
    USB to rs232 25 pin
    I'm trying to hook up a laptop to an okuma osp5020m. my laptop has USB ports. is this possible? if so, how would i go about getting the correct cable?
    Oct 2008
    105
    You have to get a cable built. You need the Okuma MAP on one end, a junction box, then USB. I have seen them...
    Contact WireWise, Inc. in Gastonia NC You can Google it for the phone number.
    They made mine =)
    Feb 2009
    6028
    Quote Originally Posted by jpwilliams4 View Post
    All you need is the USB serial adapter, available for ~10 bucks at most computer shops.
    Oct 2008
    105
    Quote Originally Posted by underthetire View Post
    That's only if he has the correct serial cable adapter in hand. The pin-out has to be matched...and the standard PC serial and the Okuma serial is not 1:1.
    The correct pin-out mapping is a little higher in this forum post.
    May 2018
    74
    Re: Need Help with rs232 connection LB-15
    Quote Originally Posted by WGJ View Post
    Hi WGJ,I am trying to connect my pc to my machines. We have LB10, 12, 15 with OSP500L/5000L-G. Can you show me more details how to connect, what cables and configuration to get the connection works...I want to see how do the READ/GET/PUT commands work on transferring data between pc and machine.Thanks a lot
  1. USB to RS232 connection
    By stevo1 in forum DNC Problems and Solutions
    Last Post: 02-12-2020, 10:57 PM
  2. RS232 connection
    By mamehdi2000 in forum DynaCNC
    Last Post: 04-21-2014, 07:43 PM
  3. pc-2100 rs232 connection
    By blues_12 in forum DNC Problems and Solutions
    Last Post: 12-05-2013, 10:56 PM
  4. RS232 connection
    By ramsey321 in forum Tree
    Last Post: 02-05-2011, 09:15 PM
  5. fidia rs232 connection
    By digitallan in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2008, 10:28 PM
