585,997 active members*
5,068 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > stepper motor load resistor and figuring out phases?
Results 1 to 8 of 8
    Mar 2005
    I bought a stepper motor controller a while a go, a small simple one from Herbach, and recently tried to connect it to a new motor- the chip blew up. I then looked at the info sheet and realized I should have used load resistors (the motor I had on it before worked fine without load resistors). SO I bought a new controller, and before I connect it to the motor, can anyone help confirm what size resistors I should be using? I have two options for the motor:
    1. Superior Electric slo-syn motor- 11v DC, .44 amps, 8 wire. I assume this is four coils, so using the formula I received with the controller (Rload = +V-Vcoil/ Icoil) I get (11v-2.75v/ 440) and get 18.75 ohms? is this the correct rating for the resistor? what size wattage resistor should I use?
    2 (second option)- 5vdc, 3.5w motor, 8 wire. so that would be (calculating .7 amp because of the watts) 5v-1.25v/700ma= 5.35 ohms? These readings seem very small.
    ALSO- on the Superior Electric, I have found the pairs in the eight wires, but how do you figure out the sequence of the coils- trial and error?
    Thanks for any help anyone can give. I realize by looking over all the threads that I am asking simple, newby questions, but hopefully someone out there can spare the time.
    Thanks in advance...
    66
    What is your power supply voltage??
    Mar 2005
    12 volts- the board says it can handle 5- 30v.
    1695
    You also need to know the rating of your controller, since that is what blew up last time.
    Dec 2004
    518
    Some info
    I Googled "slo-syn stepper 8 wire" and found http://www.bessrc.aps.anl.gov/Steppe...nnections.html. Looking at their page, they show an 8 wire slo-syn (by color code) as:
    Phase 1+: Red, Phase 1-: Blk
    Phase 2+: Red/Wht, Phase 2-:Wht
    Phase 3+: Grn, Phase 3-: Org
    Phase 4+: Grn/Wht, Phase 4-: Wht/Blk
    Google is our friend! At least if your wires are these colors.
    Your controller is rated to 30 VDC and 1.25 Amps per phase. As far I can tell from the ads on the Herbach site, this is not a chopper-type controller. Because of this, power it with a supply close to the stepper's requirements: 12 VDC.
    Using ohms law R = V/I; 12 V/0.44A = 27.3 Ohms. Nearest standard values are 24, 27, 30, and 33 ohms. Use the 27 ohm or a higher value.
    Power dissipated is I*I*R. So, assuming 27 Ohms @ 0.44 Amps, Power dissipated will be 0.44 A*0.44 A*27 Ohms, or 5.23 Watts.
    You will most likely find 5 Watt or 10 Watt resistors-use the higher rating. Running a 5 watter at 5 watts is like running your car all day long at 6000 RPM. It might be rated for 6000 RPM, but not continuously.
    So: 27 Ohm, 10 Watt resistors for a 12 Volt supply. Hmmm. Better make sure your supply is good for a couple of amps too. Again, overkill is good-don't run right up against the ragged limit.
    Have fun!
    1695
    Quote Originally Posted by Evodyne
    They sure am! I shorted their stock at $200 so the more it goes down, the more :banana: I'll be doing.
    Dec 2004
    518
    Hmmm...
    Kind of makes me wish I'd caught that train with you! A day late and a dollar short. Oh well!
    Mar 2005
    Thank you peepols
    Well God Bless,
    Thank you all for your wonderful help. I had done some googling but I was just looking for the company and hoping to find specs and diagrams there, but alas, I guess the motor is old (it's a surplus buy). Again thank you all. This cnczone is great.
  1. Attaching a Stepper
    By andy_ck87028 in forum DIY CNC Router Table Machines
    Last Post: 12-24-2004, 06:09 PM
  2. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  3. Stepper Resolution
    By Max in forum DIY CNC Router Table Machines
    Last Post: 09-05-2004, 09:06 AM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
