509,571 active members
3,772 visitors online
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > G71/G72 type I vs. type II cycles
    Registered
    Feb 2006
    1770
    Type I cycles require that there be monotonic increase or decrease in the part diameter, along its length ... Everybody knows that.
    Type II cycles relax this requirement. Diameter can vary in any arbitrary manner.
    The surface finish by type II cycles is better than that obtained through type I cycles, because type II cycles do not create steps during roughing operations, obviating the need for G70 (unless a finishing tool is desired to be used in the end).
    Now the question:
    Why use type I cycle at all, when type II also can be used for monotonic increase or decrease in diameter?
    Is there any specific advantage in type I cycles which is not there in type II cycles?
    Is there an example where only type I can be used?
    Some expert machinist may have the answer.
    Thanks in advance.
    Gold Member
    Jun 2008
    1511
    Sinha,
    There may be a reason out there but I don’t use type I cycles. I only use typeII. If I had to ass u me then I would think this is the same scenario as macroA and macroB. Even though most people use B instead of A, the A option is stilled offered. It could be that when typeII was developed they designed it using things with typeI so they needed to keep typeI.
    Stevo
    Registered
    Aug 2010
    i have a fanuc 16t control and i would like to use a g71 to cut an internal profile with and undercut but the machine wants to do the undercut in 1 cut how can I get it to rough it first
    Gold Member
    2924
    Quote Originally Posted by derek68 View Post
    Why not post your program here, so maybe we can see what's wrong?
    Registered
    Feb 2006
    1770
    G71 Type I does not rough out undercuts. It would remove the entire material in the undercut portion in the final (step-removal) pass. You have to use G71 Type II. For this, just specify both X- and Z-word in the P-block.
  1. What Type of CNC to get??
    By FUBAR62172 in forum Community Club House
    Last Post: 06-27-2009, 01:47 AM
  2. G71 type I and type II cycles
    By sinha_nsit in forum Fanuc
    Last Post: 11-03-2008, 12:34 PM
  3. What type of oil to use
    By Grego in forum Shopmaster/Shoptask
    Last Post: 12-22-2007, 08:55 PM
  4. CRC Type
    By binzer in forum GibbsCAM
    Last Post: 07-06-2007, 05:48 PM
  5. what type of CNC do I need?
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2005, 04:57 AM
