584,846 active members*
3,974 visitors online*
    Single Point Diamond Turning
    I have read many posts about SPDT and it looks like what I need to avoid polishing acrylic parts that I am CNC turning.
    The dimensions are not critical so I am looking for low-cost sources of diamond tooling. Any suggestions? TIA
    Bertho
    Oct 2004
    38
    Bertho
    Just using a monocrystalline diamond tooling will not give you a superb finish as there are other factors that contribute to achieving optical finishes. The use of fluid film bearings for both the spindle and slideways has a major impact as things like spindle runout and stiction cause major scratches although on a microscopic scale. I have seen diamond tools on ebay however i would not like to say how good they are. I would suggest you firstly buy a PCD (polycrystalline diamond) insert from ebay for about 10 pounds and see if this improves it enough and the next step i would suggest is purchase a cheap air bearing spindle one of which i have picked for less than 50 quid. You make a mount to use it in a standard lathe and this will significantly improve the asynchronous runout which is the biggest factor in surface finish whereas synchronous runout affects form. Hope this helps
    Regards
    Flannman
    Thanks Flannman,
    I looked at eBay without luck but I will keep looking. Good advice too about the air bearing spindle.
    A second reason for the diamond tooling is that the parts that I am making are very small, just a couple of mm in diameter, and I have serious heat problems with the regular tooling. I am hoping that the very sharp diamond will produce less heat.
    Thanks again,
    Bertho
    Jan 2008
    39
    Quote Originally Posted by Bertho View Post
    Bertho
    Bertho,
    Please feel free to send me a pm with your specifications/requirements with regards to the diamond tools that you are looking for. I would be more than happy to try and help you out.
    K&Y Diamond Ltd. - Ph514) 333-5606, Fax514) 339-5493
    http://www.kydiamond.ca
    Feb 2017
    Re: Single Point Diamond Turning
    Everything You Want To Learn About Diamond Turning:
    https://syntecoptics.com/blog/everyt...mond-turning-2
  1. diamond turning
    By gits in forum Glass, Plastic and Stone
    Last Post: 10-26-2011, 05:07 AM
  2. turning a 5/8-18 unjf 3A p/p single point
    By Brandhoff1234 in forum MetalWork Discussion
    Last Post: 11-16-2010, 10:00 PM
  3. SOFTWARE for PHOTO ENGRAVE WITH DIAMOND POINT TOOL
    By candino in forum Engraving Machines
    Last Post: 03-07-2008, 06:33 PM
  4. Single Point Diamond Tool Relapping
    By ImanCarrot in forum Toolgrinding / Toolgrinding Machines
    Last Post: 11-14-2005, 05:27 PM
