585,758 active members*
4,456 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori MV-JR Power down during ATC error - Please help!
Results 1 to 8 of 8
    Aug 2008
    10
    Question Mori MV-JR Power down during ATC error - Please help!
    Hi all,
    Similar to mshopsteve's post I have a MV-JR stuck in the midst of an ATC tool change during power down, so the machine just boots to that error (#35).
    Until I can get this figured out, can anyone help me bypass this? Can I jumper something, or are there some M-codes to reset it? I really need to get this machine running now, and can afford to go back and fix things properly at a later date. Even doing manual tool changes right now would let me get some jobs out the door, if only I could get past this alarm.
    Please help if you can!
    Best Regards,
    Damian
    Feb 2009
    6028
    MV JR ATC
    Check other post For MVjr. It is not something you can bypass. Well you can, but its really not to hard to fix the problem. Try that first.
    Sep 2008
    67
    [QUOTE=dddamian;668130]Hi all,
    Best Regards,
    mek machie to MDI "M31;"inset M35;insert START, sty pushing "+X"
    after go to keepl K8.0 mek it to 0
    to finish "M32"
    restart machine
    its all
    Aug 2008
    10
    Thanks lmostafa - keeprl 8 is the key. As long as it's latched in there is little you can do with the machine....
    Sep 2008
    67
    pleas in need a hand book for fanuc OM OT maintenace book;connecting book.
    if you have hit send by email : [email protected]
    thaks
    Sep 2008
    67
    please i need help i want have a document maitenace for fanuc OT;OM .
    if a man have hit send mi by email:[email protected]
    Re: Mori MV-JR Power down during ATC error - Please help!
    Need some help
    I have a Mori Seiki MV-80
    Tool change command was send when z axis wasn’t home.
    Now I’m stuck with the pocket down.
    Any help how to get the pocket back in place?
    hello, Good morning, i'm searching the manuals of this machine, do you have them and could you share them with me, please?
  1. mori mv jr magazine index error
    By dannystooblue in forum Mori Seiki Mills
    Last Post: 12-26-2023, 09:38 PM
  2. Mori Seiki Fanuc 3T error
    By haitd in forum Fanuc
    Last Post: 03-08-2012, 08:51 PM
  3. Mori MV JR CPU Error now no power to screen
    By schmidtmotorwor in forum Mori Seiki Mills
    Last Post: 04-02-2010, 03:37 AM
  4. Mori MV-JR Power off during ATC cycle error
    By dddamian in forum Fanuc
    Last Post: 09-23-2009, 03:17 AM
  5. mori jr w/10m atc power off error
    By mshopsteve in forum Mori Seiki Mills
    Last Post: 09-01-2009, 11:58 AM
