585,894 active members*
4,155 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > C Axis Fault Motor Overload Error #27
Results 1 to 7 of 7
    Aug 2009
    11
    Hello, I have a Fadal 4020 and everything runs great no errors
    I wrote a program using rigidtap and when the program ends it
    sends the machine home and then the machine errors out with
    C Axis Fault Motor Overload Error #27 press jog to release.
    Is there something i am doing wrong?
    in the program i am using S450.2 F22.5 this is for a 1/4-20 tap
    I appreciate any help thank you.
    Jeff
    Sep 2009
    181
    From what you said:
    -RPM of the spindle may not be right. What kind of inverter do you have? Does the inverter have a display that shows the Hz or RPM? When you run at 500RPM the display of the inverter should show 1000RPM. Or get a tach to check the RPM of the spindle.
    -Clock speed of the axis travel may not be right. Check the clock speed and set for what is recommended in the manual.
    -The gain in the SETP may not be right.
    Hope I was of some help.
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Aug 2009
    11
    Hello, I ran the program without a part and it did not error out.
    I ran through 5 times without any errors but i wasn't cut anything
    either. I did notice that the rpm is programmed at s450.2 but the speed
    shows up in the rpm box as a negitive number is this correct?
    Should the correct speed show up under rpm box or am i using
    a diffrent format?
    This is the first time i am running rigid tap, I am not sure what its
    suppose to look like.
    thanks for the help
    Jeff
    900
    wdwrd68--
    That error code refers to the spindle magnet not being seen within 6 seconds at the completion of the rigidtap cycle in order to re-orient. This may be to a calibration sstting that is on the edge and may need to be touched up.
    Neal
    Aug 2009
    11
    Hi Neal, Is this something you can help me out with or do i have to have FADAL come out and adjust it for me. I just purchased the machine shop
    around 4 months ago and this is the first problem that i have had. I ran another part this morning and what you say makes since. I dont receive the error till after the machine is at the home position which take a few seconds to return home then i get the error. I will send you a PM with my info.
    I am new at this forum and i really enjoy reading and learning and appreciate all the help you guys give.
    Thank You,
    Jeff
    900
    If it is a calibration issue, you will need a tech to do it as it requires a special thread standard to accomplish.
    Neal
    Aug 2009
    11
    Hello Everyone, I am just giving a follow-up post letting everyone
    know that i had the service tech come out and he had to re-calibrate
    the inverter in the back of the machine. Everything is working great.
    thanks jeff
  1. Error 55 motor overload (T1)
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-27-2019, 01:05 PM
  2. VMC15 error #3 motor overload (Z)
    By timo2le in forum Fadal
    Last Post: 06-26-2014, 02:10 PM
  3. C Axis Motor Overload
    By Paul Petersen in forum Fadal
    Last Post: 12-19-2007, 01:11 PM
  4. 1995 VMC15 Error#3 Motor overload
    By Billet Sean in forum Fadal
    Last Post: 03-07-2007, 09:39 PM
  5. TC-22 Z-Axis Current Motor Overload
    By PPM in forum Bridgeport / Hardinge Mills
    Last Post: 08-11-2005, 07:09 PM
