HI
how can I fix "Soft Stop" error message on machine Disply
I made a file with lasercut 5.3 and download it via USB Stick.
I hope anybody can help me
Thank you
bye
spot-box
HI
Thank you
bye
spot-box
Spotbox,
First, with the laser on, you must Download Config to the laser from LaserCut using the usb cable. Or Export Config to your portable usb drive, then run it in the laser and it should beep when done.
Also see HERE for another soft stop error thread.
That's the best I can do. Does your DLL and Firmware match now? Did you get that fixed?
Skip
