I am looking for a small mill and lathe for my garage. The space is 36"D X 120"L X 80"H on about 3" thk of old uneven concrete. It is currently below my residence and not well insulated for noise. The service coming in is 100 amp. 220V 30 Amp is readily available.
I will mostly machine one off motorcycle parts. The main material will be aluminum. Some potential projects: camera mounts, rearsets mods, steel and alum tubing, bushings, brackets, sliders, clip-ons, bar ends, lightening holes in discs, maybe even gears. Definitely need to do metric threads on the lathe. Metric dials would be nice but not required.
For work related parts, it is likely be aluminum, steel, and 300 series SS parts. These would also be one off mostly tapped holes. Most tolerances will be +/-.005". There will be the occasional +/-.001" for dowels. Max. drilled holes sizes will be about 1 inch. A machinist used to say "If it is too big to fit in your car, it just got expensive." My saying will be "If it can't fit in my backpack, I can't do it."
For the mill, I would like to get the mill first. I want a path to upgrade to DRO. I also want a path to upgrade to CNC. I can imagine getting very creative with a XYZ CNC! I don't think I will need to CNC the lathe. I would still like to have it as an option.
As for investment, my ballpark is between $5k to $10k for both machines. I don't like to buy disposable tools or try to get lucky on a tool working. I believe quality is made from quality. I don't want to get into a situation where I am spending my free time working on the machinery.
I am a mechanical engineer and have used varies manual mills and lathes. If I have the time, I can do some very nice work. I am familiar with, but have never operated a CNC mill before. I am not familiar at all with how well the bench top models perform. My plan was to buy a Bridgeport, but I just don't have the room.
Can someone recommend a machine which is capable of making these parts? Anybody local around San Francisco that I can check on out? I have a few in mind but I don't want to influence suggestions.
Thanks in advance!
