HI
Anyone have any information on this power supply . a drawing would be great But I know thats grasping for straws......Any help would be greatly appreaiceated...thanks to all ...
HI
Imay have drawing, what is the machine tool? what is the control? and what is wrong with yours? Many of these units were interchaneable.
The machine is a EDM ,the machine has a om-a control...the main board is a A16B-1010-0210...The power supply board A16B-1210-0660 Keeps blowing the 3.2 amp fuse....If I replace the fuse machine will come up for a couple of minutes then blow the 3.2 amp fuse on the main board power supply...thanks for your help...
The 3.2 amp fuse supplies 24v to the front panel and CRT, I/O
I would pull the I/O board then turn on the control, the machine will not come up, wait a few minutes to see if the fuse blows. If it still blows disconnect Crt and try again, if it does not blow put I/O board back in with all connectors off (M1,M2,M18,M19,M20)
Try turning on again, If fuse does not blow,try putting one connector back on at a time, until you find the connector that is causing the fuse to blow. Once you find the connector look at your electrical drawings to see what that connector supplies.
Now Im confused ....power supply calls for mp-32 fuse......3.2 amp all I have left are smp-32...a 3.2 amp fuse , now fuse is not blowing...Is having a smp fuse in there a bad thing.....?
Best I can remenber SMP is slow blow probably not real critical. for i/o related.
I think that there is no issue w power supply.
Try our friends solution ie isolatiom if fuse starts blowing.
The sugestion on pulling the I/O board is a good one...and I did try that..Thats why I thought there was a big differance in the fuse type...I did get the mp fuses off ebay baybe it was really old .and ready to blow...The drawings I got for the machine are for a machine with a 6m my machine has a om-a so I am realy lost when it comes to tracking anything down . Wish I could find some drawings for a om-a control...thanks to everone for there help thanks...see you guys later....
