Hello guys,
My first post and need some help finding parts for a Jet JMD18 Drill/Mill. I was given the Mill and it's in nice/ok shape. I own a lathe but never done anything on a mill.
I'm taking it semi apart/cleaning it. There is no wear in the table screws or brass nuts. They are split nuts so i took up a couple of turns to tighten them a bit. The ways a fine no signs of any wear. I can't feel any play in the spindle but that's probably not a test. I was told it was mostly used as a drill press.
I need a table handwheel, a face plate, the handwheel for the spindle and a few other things. I would like factory replacement parts.
It took a while but the only place i found to buy parts is
Walter Meier. I placed an order but i don't think it went thru. I called they said they will let me know in 48 hrs if they got the order, sorta funky if you ask me. Is there someplace else to order factory parts, is this place legit??
thanks!! joe
