585,886 active members*
5,548 visitors online*
    Sep 2009
    4
    Need Help With Conversion
    I am trying to convert the stepper motors on a F1 mill to servos. I have the motor number but havent the foggiest idea how to find suitable replacements. Any help would be greatly appreciated. Thanks
    24221
    Do you have the constant Torque sizing of the old motors?
    You may find that the comparable servo sizing is a NEMA frame larger than the Stepper motors.
    Al.
    Albert E.
    Sep 2009
    4
    Im not sure what the constant torque sizing is but in the manual (under all the dust that has accumulated over the last 3 years) it gives a feed force of 255 lbs. I will continue looking tomorrow when i return to the school.
    Sep 2009
    4
    I was unable to come up with a specific torque rating for the stepper motors but i am certain they are the original ones. I do have the motor numbers if that would help at all. I dont know if i mentioned it before but these are most likely to be used in a motor control class (hence the reason for the conversion from stepper to servo) These two machines (both EMCO, one model F1 mill and the other, model compact5 lathe) were started to be converted to a PC based system about 3 or 4 years ago and eventually forgotten. I have been given the task of converting them to servos and completing the programming side as well. so any help at all would be most appreciated.
    Jul 2017
    10
    Re: Need Help With Conversion
    Hi there.
    I just buy a Emco F1 CNC mill from a local school. It is in good condition, powers on and all the axis move. I'll work on the same problem. Do you figured out what are suitable servo motors for replacements?? Any information or picture of your project would help me. I'm new on this forum and this branch, so any help would be great. Thanks
  1. CMM to CNC Conversion
    By JEsler in forum Open Source CNC Machine Designs
    Last Post: 03-19-2010, 04:14 AM
  2. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  3. Just another X2 conversion
    By christofer in forum Benchtop Machines
    Last Post: 07-16-2008, 04:44 PM
  4. The best conversion kit for X3
    By triump in forum Syil Products
    Last Post: 11-11-2006, 01:59 PM
  5. a conversion Kit for CNC
    By US-GUN'S in forum Benchtop Machines
    Last Post: 08-10-2006, 04:23 PM
