585,760 active members*
3,717 visitors online*
Thread: Roboform 400
    Jun 2003
    63
    Roboform 400
    I have a Roboform 400 that keeps shutting down with an E909 error (Main Voltage too low). The voltage to the step up transformer and the voltage out of the transformer are good but machine continues to shut down at random and keeps giving me an E909 error. Any Suggestions?
    Jan 2006
    104
    for whatever reason, charmilles decided to measure the value of the 80 volt dc "well" voltage to monitor "mains too low" so if you get that error, you need to change (or at least check) the K2 (i think) relay....it comes on when the cutting section comes on.....
    this relay supplies the raw ac voltage to the rectifiers which generate the 80 vdc cutting voltage, this circuit is unregulated, so you get a "mains too low" error if the 80 vdc is too low......go figure.....
    it seems the contacts on the relay get arc'ed so they start to drop voltage after years of use....
    hellava way to check the AC mains supply......
    it seems that charmilles is only interested in "mains too low" only when the cutting section is fired up.....
    i believe this is done to keep technology in spec.....
    good luck,
    michael
    Registered Linux User #348337
    EMC2 Rocks!!!!
    Mar 2013
    8
    Re: Roboform 400
    Quote Originally Posted by bocko912 View Post
    Hello, hope you are doing well, I have a roboform 22 and i am having the same issue but the program wont even start, I just hit he cycle start and then I get this alarm.
    did you solve your problem?
  1. Charmilles Roboform 200 - HELP!
    By toolnuts in forum Waterjet General Topics
    Last Post: 11-04-2021, 03:46 PM
  2. roboform c axis
    By rwkjr in forum EDM Discussion General Topics
    Last Post: 08-18-2017, 07:25 PM
  3. Charmille Roboform 200
    By ErnieD in forum Moldmaking
    Last Post: 07-23-2014, 01:14 AM
  4. charmilles roboform 550
    By miller04 in forum EDM Discussion General Topics
    Last Post: 10-29-2010, 06:31 PM
  5. schematics for a Roboform 400
    By jetski in forum EDM Discussion General Topics
    Last Post: 10-19-2010, 01:22 AM
