Dear Bobs,
Thanks for your responses.
I couldn't understand some of your comments
Your data grab seems to start with a data value of 10101010 for synchronisation then have about 4 data values of 00000000
When I look at the picture I see 11001100 first not 10101010 Do I miss something.
Also what do you mean 4 adata values of 00000000 ? There is no back to back eigth zeros there ?
You see I attached a general serial port pics and The baudrate it mention is calculated with one bit not with 2 bits. And plus When I set the baudrate to 4MHz on embedded side datas dumped datas were not stable But When I set it to 8MHz dumped datas were pearly Actually I could not get precise datas with any Baudrates except 8MHz on embedded side. So I may insist that the baudrate is 8MHz ? Do you have any comments ?
- When You look at the signal can you be sure it is manchaster ? I have no knowledge about that. I think you have ?
I update the osc. screen with period explanation
