Originally Posted by
cfordyce05
Well, it has officially begun. After some saggy trailer moments and I neighbor with a 11000 lb forklift, the mill is in the garage ready to be cleaned up a bit. Not a bad haul at roughly $400 for the mill and transportation.
Congrats on getting it home safely. Nothing worse than getting hurt trying to save money.
Depending on the motors, power supply and how fast you want to go, the general answer is yes, the G320x will most likely work, even if you have to put in a lower voltage power supply.
How about a few pics?
If you have analog servo amps on the machine and they are in good working condition, take a look at the DSPMC/ip from Vital systems. It is more expensive than the smooth stepper but you get encoder feedback into Mach3 and a ton of I/O. Plus it has user settable pid and a bunch of cool features.
I use it on my mill and I am very happy with it. The Hitachi sj200?series is a nice VFD. I use a 3 hp one and once you get the parameters set, it is rock solid.
My build log is here.
http://www.cnczone.com/forums/showthread.php?t=66994
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
