585,977 active members*
4,235 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Gecko 540 & CNC4PC C6 Board
Results 1 to 10 of 10
    Aug 2009
    42
    Has anyone tried to connect a Gecko 540 to a CNC4PC C6 spindle control board while using Mach3? I have the 12 volt power supply connection figured out but I'm still trying to figure out to get the signal out of the Gecko 540 and into the C6 board. I know that it takes 3 wires but I'm just not sure of the combination.
    Can anyone help me.
    Dec 2004
    1865
    Quote Originally Posted by john1285 View Post
    Can anyone help me.
    If I understand this correctly, the C6 board outputs a 0-10v for VFD control.
    The G540 already has that feature built in, so I am a little confused.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Feb 2007
    4553
    Question
    The Gecko G540 VFD output is basically the same as the CNC4PC C6 VFD output minus the additional relays.
    What you are attempting is redundant.
    You do not need the C6 control with a G540.
    What are you using for a speed controller?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Smile
    TOTALLYRC,
    Déjà vu, did you notice the time we both posted?
    Jeff...
    Aug 2009
    42
    I don't have a VFD
    I don't have a VFD, I am trying to hook this up to a SIEG X2 Mini Mill that has a DC Brush motor with a potentiometer but I can disconnect that after I get some sort of signal to my CNC4PC C6 Board. I have it hooked up per the instructions that came with the C6 board, but when I try to turn on the spindle I get an error on output #2.
    Dec 2004
    1865
    Quote Originally Posted by jalessi View Post
    TOTALLYRC,
    Jeff...
    Very serendipitous, don't you think?
    The G540 should do the same thing as you are just trying to supply the dc motor board with a 0-10v volt signal and the G540 does that, unless I am completely mistaken, and it wouldn't be the first time.
    Feb 2007
    4553
    Post
    John,
    Most likely the center connection on the potentiometer is the speed input, that wire would connect to the G540 pin number eight (8).
    If you measure the voltage on the outboard potentiometer connections one side should be ground, connect G540 pin seven (7) to that wire.
    The other outboard potentiometer connection should be under 12 volts d.c.,
    connect that side to G540 pin nine (9).
    If the voltage is over 12 volts d.c. do not connect the G540 it will be damaged.
    The potentiometer should be removed in order for this to work.
    Jeff...
    Feb 2007
    4553
    Post
    John,
    You do not need the C6 with the G540, remove it.
    Jeff...
    Aug 2009
    42
    Spindle control of X2 Mini Mill
    It is now working, but I didn't figure it out, my friend Phil did and he explains very clearly how to do it here:
    http://pminmo.com/g540-vfd
    My X2 mini mill is now working very well with Mach3, Gecko G540 and a M3 and a Sxxxx command turns on the spindle and sets the speed. You don't need a C6 board, I returned it.
    Thanks for everyones help
    Jack
    May 2013
    14
    Re: Spindle control of X2 Mini Mill
    404: Page not found - HostGator
    Jack
    Please how did you achieve this the information link does not exist anymore!!!
    Please help
  1. Upgrading to Gecko from cnc4pc c11 & xylotex
    By Vogavt in forum CNC Machine Related Electronics
    Last Post: 08-11-2012, 12:22 AM
  2. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
  3. cnc4pc c11g gecko
    By Nono in forum DIY CNC Router Table Machines
    Last Post: 09-06-2008, 12:12 PM
  4. Gecko Cnc4pc Wiring Diagram
    By mlaws1172 in forum Waterjet General Topics
    Last Post: 09-15-2005, 12:14 AM
