586,009 active members*
4,893 visitors online*
    Feb 2006
    77
    Short circuit protection
    Hey all,
    Have been on the lookout for a schematic kinda like a crowbar circuit but instead of using an SCR and blowing a fuse I want it to pull a relay and disconnect the load.
    My fancy lab PSU has this feature and I want to use the circuit in a high current PSU .
    Have looked all over the net.
    Have had an idea with a shunt resistor and even an opamp but not really sure which way to go.
    Anyone got any good tips, ideas or a circuit.
    Cheers
    Mar 2008
    267
    Hello Beaker,
    do a bit of searching on "fold back current limit"
    I know this is not the nature of answer You want and if i were in Your shoes i might get agranoyed with this kind of response.
    This is the best i can do with the information You have supplied ( load voltage and current would be a nice start).
    Feb 2006
    77
    Hey Zig,
    All info is good info, will be sure to check it out. Thanks
    What I would like the circuit to do is:
    When the power supply's output is shorted a relay disconnects the output and stays that way until the short is removed then reconnects the output.
    Cheers
    Jan 2006
    738
    Sounds interesting.... One problem I see is that using a relay to disconnect the load would not allow the circuit to sense the load current while disconnected. The bench supply I use has adjustable current limit and it's circuit is probably similar to the one here....
    http://freecircuitdiagram.com/2008/0...miter-circuit/
    It won't shut off the current entirely, but will limit to a set value.
    Steve
  1. g-rex open-circuit protection?
    By Claude Boudreau in forum Gecko Drives
    Last Post: 02-20-2009, 11:32 PM
  2. Stepper Motor Short circuit??
    By dak70 in forum Stepper Motors / Drives
    Last Post: 06-23-2008, 03:07 AM
  3. Short circuit question
    By Tomax in forum CNC Machine Related Electronics
    Last Post: 04-30-2008, 03:46 AM
  4. Protection
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 01-04-2007, 01:15 AM
  5. Way Protection
    By mgamber in forum Benchtop Machines
    Last Post: 03-10-2003, 01:59 AM
