584,879 active members*
5,352 visitors online*
Results 1 to 10 of 10
    Oct 2009
    Johnford lathe
    We have a Johnford lathe with a fanuc oi-tb controller. the controller starts okay the gives a 1107 turret servo alarm. What should i be looking for?
    You should be looking for your
    MTB Manual with alarm descriptions ......
    A turret servo alarm is not a Fanuc alarm
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Oct 2009
    Cool re. Johnford
    I realize that it's not a fanuc problem. there is not a mitsu turret board on this site, and I can't figure out what these people did with the manual.
    Just throwing spaghetti on the wall. Thanks Monkey
    OK A few more details wouldn't go amiss !!
    I.E.
    Machine Manufacturer + Model
    Control Manufacturer + Model
    Relevant Servo Amplifier and Motor Models
    And a description of what is happening/not happening
    With this info we can start to help
    If it is a Mitsubishi Control I suggest you post this info in this forum
    http://www.cnczone.com/forums/forumdisplay.php?f=111
    Jul 2011
    i have the same problem.1107 turret servo alarm..its a johnford sl-500 with the fanuc oi-tb controller,it has the golden sun turret on it,i cant get the alarm to clear,or zero the machine out or anything...any help????thanks
    Apr 2013
    14
    Re: Johnford lathe
    I just got this error fixed on my Johnford SL-300 after crashing the turret. I followed these instructions from my manual, and it worked.
    May 2018
    Quote Originally Posted by evilusions View Post
    This is on page 53 on in the operation manual.
    Mar 2009
    29
    Re: Johnford lathe
    Quote Originally Posted by speedmaster View Post
    We have found that this alarm can not be cleared until changing the 3.6v lithium battery located on the turret drive in the main cabinet out back. We do this battery change while the machine is powered up. After the battery is replaced we go through the turret resetting routine found in the machines manual.
    Nov 2022
    Re: Johnford lathe
    Fixed or not
    Nov 2022
    Quote Originally Posted by tdl1 View Post
    Fixed or not
  1. Using the touch-off probe in a Johnford Lathe 650A.
    By hiatec in forum MetalWork Discussion
    Last Post: 07-08-2011, 07:22 PM
  2. Johnford TC-65
    By meinternational in forum Fanuc
    Last Post: 02-15-2010, 01:04 PM
  3. Lathe JohnFord with Fanuc 18 - need help
    By longgo in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2009, 07:01 PM
  4. FANUC 0i for Johnford lathe 2 axis
    By Arsalan Ahmad in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2009, 09:13 AM
  5. JOHNFORD VMC
    By ALEXCOMO in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2008, 01:07 PM
