585,982 active members*
4,667 visitors online*
    Apr 2004
    79
    Question Anyone done a homemade B.T.R.
    I have a Burgmaster VMC w/ 6M-b that has about 5k of memory and would like to try some 3d shapes but can't justify the grand the an over the counter BTR cost. I can up/download programs with Cadem but tape mode does nothing as far as the rs-232 goes. I would like to make a led array to feed the tape reader and opto for flow control.All input welcome no pun intended.
    24221
    I once made the reverse, kinda, I used a older UART IC IM6402 to take the output from a tape reader (parallel) and convert to RS232, It should be possible to use an IC like this the other way around and input RS232 and convert to parallel data ( it has both transmit and recieve registers).
    You would need to simulate the sprocket hole which is usually used for clocking the data, there should be a signal for this in a UART and also an input to simulate tape pause.
    I believe the commercial ones also have an internal buffer.
    Al
    Albert E.
    Apr 2004
    79
    I plan on using the parallel port to do this. I have an old dos program called CNC File that will do this but the BTR that I had left with the old GE 550 control when I retrofited my HNC to an AH-HA pc control. I don't plan on using the drip feed very often as the rs-232 works for 95+% of what I make.
    Apr 2004
    79
    I found a interface card @ http://cnc4pc.com/Parallel_Port_Interface_Card.htm
    that I think will be a big help with this project.
  1. Confused about CNC software
    By samualt in forum Uncategorised CAM Discussion
    Last Post: 07-01-2005, 02:18 AM
  2. Homemade PCB 'fit and finish'
    By shadow in forum CNC Machine Related Electronics
    Last Post: 02-06-2005, 01:01 AM
  3. Servo idea: Windscreen-wiper motor w. homemade encoder
    By Evilness in forum DIY CNC Router Table Machines
    Last Post: 05-03-2004, 07:24 PM
  4. NEWBIE!!! Confused with 3d Routering and Milling
    By Sanghera in forum Uncategorised CAM Discussion
    Last Post: 04-20-2004, 03:58 AM
  5. Where to get cheap parts for a Homemade Router
    By teilhardo in forum DIY CNC Router Table Machines
    Last Post: 03-15-2004, 03:09 AM
