585,743 active members*
4,775 visitors online*
Results 1 to 11 of 11
    Dec 2006
    34
    Router Vacuum Attachment...
    I have a DynaCNC table with a Porter Cable variable speed router. I need to cut down on the dust in my garage and want to purchase or make a vacuum attachemt for the router head. Anyone know where I can buy one or have recommentations on how to make one? I can't seem to find anywhere to purchase the "Brush" material to put around a mounting plate to attach to the bottom of the router. Any suggestions would be appreciated. I tried to search the forums but didn't find any information on this subject.
    Nov 2007
    2466
    i have done this with clear acylic for visibility using the mc brushes
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Dec 2006
    34
    Quote Originally Posted by cabnet636 View Post
    jim
    Acrylic was what I was thinking also. I just need to figure out a way to make it quick and easy to detach from the router for bit changes.
    128
    jim
    Hi, nice setup. What is the bristle length on those brushes? from whome can one purchase these?
    Check out some of my vids: http://www.youtube.com/user/blauschuh
    Nov 2007
    2466
    mcmaster carr in atlanta, make sure to get nylon 2" as the horse hair is too stiff
    jim
    128
    jim
    thanks alot... going to order up some 2 and 4"
    Jun 2008
    562
    Quote Originally Posted by Mini-MillX2 View Post
    I'm going to try the clear vinyl used in strip curtains(instead of brushes) about 3-4 inches long. Cut 2-3" deep slits in vinyl about 1" apart at bottom. Mount the vinyl on piano hinge and then mount hinge on the main plate to hook up the vacuum. That way I can see what going on with the bit while running and also flip up the vinyl when changing bits or when not needed.
    I'll post pics when I get it done.
    Mike
    Sep 2009
    277
    Did the strip curtain type vinyl work???
    Quote Originally Posted by Mike 1948 View Post
    Mike
    Jun 2008
    562
    It works fairly well but chips still get out at the corners. At least I can see what the cutter is doing and its better than nothing.
    Mike
    Sep 2009
    277
    Awesome thanks Mike. I'm buying some 200mm.w x 2mm thick. I'll buy a meter and try it.
    Sent from my GT-N7100 using Tapatalk
  1. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  2. Vacuum Table for large CNC router
    By stairgod in forum Commercial CNC Wood Routers
    Last Post: 07-15-2011, 06:16 AM
  3. Vacuum Table for CNC router
    By marting in forum DIY CNC Router Table Machines
    Last Post: 04-30-2007, 12:15 AM
  4. Anyone knows what's this attachment and what's the use??
    By cbucner in forum MetalWork Discussion
    Last Post: 04-04-2006, 04:04 AM
  5. Vacuum router bed
    By speedracer in forum DNC Problems and Solutions
    Last Post: 06-17-2003, 07:11 PM
